1990 HO 5.0 with Edelbrock 1405 carb. and slightly lopey Comp Cam and long tube headers. Distributor from 1985 Mustang (I think). Upon initial install of this engine, it would backfire with the vacuum advance connected but not with advance disconnected, using the timed vacuum port. I left it disconnected and tuned the carb and drove it several months with no problems. Over the weekend, I revisited the issue. I adjusted initial timing several times between 6 and 12 degrees advanced and it did not seem to change the backfire issue. It runs good except upon very very slight application of throttle, where it backfires. No throttle or heavier throttle stops the backfire. The diaphragm holds pressure and does not leak. I even retuned the carb back to the standard tune which is about two steps richer and that had no effect either.
Why would vacuum advance cause popping from the exhaust?
