jaredsport'73
- Aug 31, 2009
- 16
I am starting an EFI swap in my 73. The motor that is currently in the truck has a noisey lifter. I figure while i gather EFI parts i might as well use one of the 302's i have on hand. I have a 1971 302 motor from a bronco with 11 thousand original miles on it. It has not ran since 1973 because of a roleover. The truck was stored inside a barn since last year when i bought it. pulled the motor and pulled the heads and every thing looks good. No water in the oil and the engine.The water jackets had some dried sludge i got most of that out with the air compressor. Or I have (option B) a 1996 bronco that i have for parts has a good running 5.0L/302 with 150000 miles on it that will have to be freshend up for sure. do I have any advantage of using this block because it has a one piece rear main seal? How much work would be needed to get the older block up to par. I am going to use GT-40 heads and explorer gt-40 intake for my efi swap, if this makes any difference in the block i should choose.
