So I just had the neighbor hone the cylinders for me and and we had it in a pretty clean out. Now I'm at the point where I'm looking to give it the final cleaning. From what I see on the net I want to use hot water and laundry soap. I was thinking the cam bearing are with a can or two of brake cleaner and the whole outside with brake cleaner. Then just give all surfaces a coat of assembly lube.
The prior to the hot water I will run some brushes the oil lines Am I missing anything?
My real concern is with the cam bearings. Not sure if I have to worry about eating a coating or something off them
