engine block codes?
joe
does anyone know of a web site that I can identify the year of a 302 and 351 from the casting codes on the block?
thanx
stlkikn
All Ford parts codes work like this...
first digit (letter) is the decade of design
second digit (number) is the model year designed for...
B= 50's, C=60's D=70's
so a part with the casting code "C6AE" would have been for '66, while a part bearing a casting code of "E2AE" would have been designed for use beginning in '82.
rednck21
so a part with the casting code "C6AE" would have been for '66, while a part bearing a cating code of "E2AE" would have been designed for use beginning in '82.
what do the 3rd and 4th digit mean?
SaddleUp
Vancouver, WA
The third one is the car line (A=Ford) and the fourth is the engineering group (E=Engine)
The following 4 digits identify what the part is. I.E. Carb, engine block, heads, tail light lense, etc.
The last digit (A, B, C, etc.) is the part revision.
rednck21
is there any way to tell which car a block came out of?? mine is from a 74 car, but not sure which car?:?
SaddleUp
Vancouver, WA
No. The closest you can come is the above. You can also usually find a date code with the casting number but that still doesn't tell you what vehicle it was originally in.
