Just a reminder that you won't be able to start new posts or reply to existings posts in the Archive forum.
All Ford parts codes work like this...
first digit (letter) is the decade of design
second digit (number) is the model year designed for...
B= 50's, C=60's D=70's
so a part with the casting code "C6AE" would have been for '66, while a part bearing a casting code of "E2AE" would have been designed for use beginning in '82.
so a part with the casting code "C6AE" would have been for '66, while a part bearing a cating code of "E2AE" would have been designed for use beginning in '82.
The third one is the car line (A=Ford) and the fourth is the engineering group (E=Engine)
The following 4 digits identify what the part is. I.E. Carb, engine block, heads, tail light lense, etc.
The last digit (A, B, C, etc.) is the part revision.
No. The closest you can come is the above. You can also usually find a date code with the casting number but that still doesn't tell you what vehicle it was originally in.
