- Jun 4, 2002
- 37,074
The good blocks were manufactured with C9-D4 casting numbers, '69-74 model years.
I go against that...
The '69 and '70 have a shorter deck height which is an old hot rodders trick for more compression. But the replacment parts are mostly based on the newer engine with the .023" taller deck. I feel that short deck is more of a liability then a benifit.
The post ~83 blocks are one piece rear main seal. and the F4 blocks are roller compatible (factory roller cam lifter bores for use with a roller cam).
Any of the 351W blocks will live with up to 700~750 HP. So going for a stronger block isn't needed, but getting a better block is a good idea. By better I mean things like newer and less wear, better sealing (rear main 1-piece), and roller cams are nice.
