JoseyWales
Hi all. When I am on the gas and let it off sharply, my engine dies. Any suggestions?
Some of the conditions...
- It happens when the engine is hot and cold.
- The fuel level in the float bowl of my Motorcraft 2bbl carb is 7/8" from the top with the engine idling.
- I have eliminated vaporlock issues.
- Engine idles at 600 RPM in gear with 14 in Hg vacuum.
- I've also had the problem with the engine idle set much higher.
- I'm running an MSD ready-to-run distributor with no control box... vacuum AND centrifugal advance.
- Timing is around 10 degrees advanced.
Other engine features...
- Long tube headers
- Weiand low-rise dual-plane intake with 1/2" thick carb adapter
- Mechanical fuel pump
- C4 tranny
- Crane powermax 2020 roller cam
- Long tube headers
- C4 tranny
