muskrat
- Aug 21, 2008
- 1,503
Hello. About ready to put the engine back in the bronco tomorrow. I went to bolt up the engine mounts and just noticed that there is definetly a left and right mount. they are not marked though, and I didn't take notice when I pulled them off the block.
I pulled a rough measurement of 4.25" and 3" from the center of the threaded stud to the mounting bolt holes that would attach the mount to the frame.
Depending on which way you use these, left side or right side, it would move the engine forward or backward.
Anyone know which is correct? Should the threaded stud to front mounting hole be the 4.25" or the 3" distance. Again, just rough measurements to make a point.
Please let me know whatcha all know.
Also, anyone know that torque spec on the bell housing to engine block? The Haynes manual I have says 25 ft pounds, but that doesn't seem like it would be enough, given the size of the bolts.
thanks.
Muskrat
thanks.
Muskrat
