slow91fj90
Ok so I got the Bronco running and went for a drive. Everything felt good for about 2 miles or when it warms up. When I came to a stop and went to drive away in first it sounded like it back fired in the intake tube for a second, then drove fine. About a mile later it while driving about 45-50 it started sputtering like it was out of gas for about 30 seconds, then back to normal. Here is some info on the truck 5.0 fuel injected explorer motor, brand new, every sensor is new and using a RJM harness. Im not currently using a VSS. Anyone have any ideas? Does this sound like a vacuum leak? Timing is set at 10 degrees.
