Engine sputtering
dougyounger
I am having a problem similar to what BGBronco was experiencing is his thread titled "Engine dying".
Similar set up to BGBronco's. I have a 77 Sport, stock 302, carburetor (I think stock Motorcraft 2100), but I have the mechanical fuel pump.
My problem is that the engine is sputtering, meaning that it acts like it is not getting gas while I am driving. I'll be driving along and then all of a sudden, it starts to lose power like it isn't getting gas and it will buck for a bit and then clear up and keep going. It will occasionally try to die as I am slowing down to make a corner or slowing to a stop. It did backfire twice very close together.
I thought maybe I had some bad gas and that it would work its way out of the problem. I added fuel treatment and have run some premium fuel.
It does this running either tank. I switched gas caps from front to back to see f it was venting correctly. The fuel pump is a couple of years old. I changed the fuel filter on the carb. I changed the air filter as I drive on a very dusty road and thought it might not be getting air. My mechanic changed the vacuum advance as it said he thought it was getting little vacuum which could cause a timing issue and cause the backfire.
My thought is the carb needs to be rebuilt. I've had the bronco a lot of years and cannot remember ever having it rebuilt. The carb does look a bit discolored like it has a lot of varnish on it.
My other thought is that I might be having a vapor lock somewhere causing it to not get gas. On BG's thread, it was suggested the ignition coil might be having issues.
Am I on the right track? Any other suggestions?
Thanks, Doug
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I had a similar problem with my '68. Carb had been rebuilt not terribly long before, I changed the fuel filters, still did it. I ended up taking the fuel lines off of the fuel pump and blowing compressed air through it. There was something in there interrupting the flow of fuel. Hooked everything back up and has worked fine for the past five years now. Cheapest fix I've ever had on an EB.
FordBronc
Bronco's, yea I have a couple.
Polk County, Missouri
I wonder what the in the tank (end of the) pick up tube filter socks are like? Are they even connected any more? Might be looking into a tank drop and a sending unit replacement.
After lots of easier/cheaper troubleshooting of course. Carb rebuild, line blow out...
dougyounger
dougyounger
The rear tank was just dropped, cleaning and a new sending unit installed about a year ago. It sputters running either tank.
I'm still thinking carb rebuild. Line blow out would probably be good too.
B RON CO
Statesville, NC
Hi, the trouble could very well be dirt in the carb.
If you are handy the carb is not hard to rebuild. Just get a carb kit and study the instructions and diagrams, and work clean and carefully. When I go over a carb I take it apart and spray carb cleaner into every passage both ways, and clean every part at least twice, and work in a clean place.
Just to be sure, check the distributor cap inside for cracks and carbon tracks, and make sure all the ignition wires are clean and tight.
Good luck
The backfiring is through the exhaust? Or is it spitting up through the carburetor?
Obviously, the term "backfire" by definition means exhaust, but I wanted to make sure since we often run into spitting out the carb too.
An exhaust backfire can also be caused by a momentarily dead ignition. A little unburned fuel makes it out of the combustion chamber and then the fire comes back and ignites the excess in the exhaust system. A boom is the result.
Do you have a tachometer? If so that's an easy way to tell if it's fuel or ignition.
SHX669
Keeping with the Tach theme ; a bad tach ground wire can cause ignition issues and " backfiring ".
Thinking out loud here ; '77 would have Duraspark ignition. Have you checked the module , and the module to tach ground wire { inside the distributor }. How about the " run circuit " resistor wire . Is it getting excessively warm - or need replaced. You can temporarily bypass it with a non resistor wire to see if that helps.
dougyounger
dougyounger
It only backfired twice a few minutes apart. The problem was happening before and has been happening since. I would say the backfire was from the exhaust but am not certain.
No, I do not have a tachometer.
SHX I am following you but you are getting above my knowledge. I have replaced the ignition module but it would have been many (10+) years ago.
I am taking the Bronco to my mechanic shortly and will address these thoughts with him.
Thanks everyone. Doug
