Engine Tick
jarch
Maybe someone who has had a similar experience can help:
302 Engine was running very smooth. Then it developed a miss at idle. Still ran smooth accelerating and at speed. I replaced spark plug wires, dist cap, rotor and air filter. Still misses at idle. I then backed out the idle mixture screws (Autolite 2100). It took about 1.5 turns at least to get the idle smooth. I also messed with the timing a little bit, but I set it back to about 14 deg BTDC. Now it idles great, but has a huge ticking sound like a major exhaust leak or stuck lifter, or something along those lines. It is very pronounced under load, but if I rev the engine in the driveway, it sounds fine. It does tick at idle though. I just rebuilt the carb last summer. I'm pulling 16 in of vacuum at 5500 ft above sea level. All vacuum lines check out, I sprayed carb cleaner around all gaskets and hoses, and can't get a different response from the engine. It is definately running like crap now.
What do you guys think? Dirt in the carb, stuck lifter? Misadjusted Rocker Arm? I can't find an obvious exhaust leak, and the fact that the ticking began after I messed with the carb screws leads me to the carb. Should I throw another rebuild kit on it tonight?
Thanks,
jarch
70_Steve
Old Guy
Get a set of valve cover gaskets. Check to see if you have a worn rocker arm.
J
jarch
Update
Rebuilt the carb last night. I didn't find any major problems with it, but put in new components / gaskets anyway. I can do that in my sleep now. It idles and runs smooth. It still ticks though. It is most pronounced at idle and under load - say 4th gear and under 2000 rpms. I put in some Rislone the other day, and it seems like it's quieting down a little bit. I used a mechanic's stethoscope (piece of wood), and the ticking is most pronounced on the passenger side bank, between the 2nd and 3rd piston. Haven't pulled the rocker covers yet.
Do you guys think it's a Rocker bolt that is backing off? Are my lifters sticking? If it's sticking lifters, is the best remedy Rislone, or Marvel Mystery Oil, or some additive to unstick them?
Thanks for the input......
pooterpot
Lumberton, Texas
sounds like mine. mine has a loud knocking sound on the pass. side around the same area you said. i havnt messed with the carb though. let me know what you find out.
clay
I had almost exactly what you are talking about. Took it to a mechanic who charged me about $200 and said it was nothing to worry about.
I got it home and just couldn't accept that so I started fiddling myself and eventually pulled the plugs. The electrode on one of the spark plugs had broken off. Replacing the plug fixed the roughness in the engine, but the tic persisted.
Eventually I pulled the head and found the electrode embedded in the piston. I pulled it out, re-assembled and all has been fine.
I've always wondered if the dimple in the piston would give me problems.
J
jarch
Update Part 2
I'm trying to get some work done in the evenings while I juggle watching my 6 month old. I keep telling him that he should pay attention because in 16 years, this ol steed could be his.........Naaaaaa. I couldn't give it up. 13 years owner and I still have it. Can't beat the classic Registration and $8/ month for full coverage classic Insurance. Anyway, here's what I did last night:
New plugs: The old ones were fine, but the gaps jumped to about .050" on some of them. I use Autolites and side gap them to about .040 with my Petronix Ignitor. Sidegapping is when you cut off some of the electrode with a hacksaw and then set the gap to the side. Supposedly, it exposes more spark to the mixture. It makes the plugs wear out faster, though. I've had good luck the past 4 years or so doing it this way.
Pulled the rocker cover. All the studs were even and the bolts were tight. I torqued them anyway. I could wiggle some of the arms back and forth, but I think this is normal. Wear seemed normal (I pulled a couple of them). Started it without the cover on - got sprayed with oil. Everything seemed to be working fine. Put silicone on gasket and reinstalled. I did have an oil leak out of the cover towards the rear of the engine.
Noticed that the wire that connects my tach to the coil was frayed in some areas (melted, and also rubbed against the throttle linkage). Put electrical tape on it.
Added 2 quarts of oil (plus the quart of Rislone the other night). My oil pressure guage was reading a little low for a while (15 psi or so). It usually reads 30-40 now that I think about it.
Tightened the header bolts, tried to place some high temp silicone along the gasket in suspect areas (I know - jerryrig). Tighened Intake Manifold bolts, although they were tight.
No time to test drive it last night. I had kid and wife duty. Will post back tomorrow after I drive it tonight. I'm kindof leaning towards exhaust leak as the culprit for the tick. I still need examine that further........
Flash69
Southwest Va
Mine did that and it was the Rocker stud. It had pulled up out of the head. I replaced them with the screw in Rocker bolts instead of press in.
J
jarch
Update 3
Test drove it this morning after the mods. A little hesitation (bogging) from the carb, which is disappointing. I'll set the float level with some more accuracy, and examine the accel pump linkage settings this weekend.
Noise is still there. Most pronounced under load. I can get the noise to occur if I rev it fast then let off the throttle in the driveway. Sounds kinda like an exhaust leak. Will examine exhaust next.
Those of you with the bent pushrods, what did you do? Replace the pushrod? Isn't there something about equal wearing parts in the drivetrain?
68ford
i had a similar noise but i think its extremely rare and probably not your problem, but i used to run my timing advanced alot and ran super, all was fine and it ran awsome, got regular on accident one time and headed up a long hill in the summer time(orange county). had the radio on loud enough that i could hear it over my 2chamber flowmasters. it was pinging up the hole hill, i finely heard it between songs. it was really that bad though, so i slowed down,pinging was almost gone. i then had i tick like an exhaust leak after that. it would also pop alittle at high rpm along with the tick. didnt have quite as much power either, but almost.
when i decided to build my engine i pulled it out and took heads off first, and there it was. number 4 intake valve had a tiny chip in it(still think from over heat from pinging) and what i was hearing was the combustion blowing back up into the cylinder, sounded like an exhaust leak and really is what is was. compesion was low at idle,but if you reved it up(no load) it would come up quite a bit, but it was enough to disrup flows at higher rpm, probably the more i put into the cylinders the more presure to make it blow back up into the intake manifold.
like i said i think this is real rare but anyone heard this before?
J
jarch
Update
We'll a coworker of mine put his foot over the exhaust while I searched for leaks. I didn't want to get too dirty, so i gave up. I then went to the hardware store to get some heater hose to listen for leaks. The noise is really loud now - not just under load, but most of the time. I looked underneath in the daylight and - there it is - a dime sixe hole in one of the header tubes. We probably made matters worse by plugging the exhaust and checking, but at least I found one of the leaks. I just did a low buck fix tonight (exhaust goop, tin, and hose clamps). This may get me by for a while until I can locate some headers and a new exhaust. Still haven't test drove it yet - will do tomorrow and post back. Hopefully this fixes it....
J
jarch
Fixed
That was the problem - exhaust leak from one of the header tubes. All noises now are recognizable and fmiliar E.B. noises.....
