Engine Tick Problem
Izzy
Texas
Ok guys, i have a problem that I have ignored in hopes of simply buying a new engine. Well that is not going to happen anytime soon so I need to try and determine what my issue is and if I can fix it cheap or if I will be better off buying a new engine.
I have a ticking noise at high RPMS\Speeds. I cannot reproduce the issue in the garage by reving the engine.
It happens when driving at about 65-70 mph and only when I'm giving it gas. Couple of examples:
1. If cruising at 70 mph and not giving it much gas, there is no noise. If I give it gas to "pass", then the tick occurs. If I give it more gas to "pass really fast", then the tick goes away again. In other words, I can throttle the gas to make the tick happen or push through it by flooring it.
2. If I try and drive faster at say 80, then the tick is constant. Again, if I floor it, it goes away.
3. This happens regardless of being in 4th or 5th gear but never happens in 1st - 3rd but I am also not reved enough or driving fast enough to occur.
4. If I leave it out of gear, and rev it up, I never hear the tick.
Not sure if this is enough info to start troubleshooting but let me know what you think or what I can look at.
I did try and put some engine cleaner in it, thinking it was maybe a sticky valve but it didn't help. I did only try one bottle on one tank of gas. Do I need to use it multiple times?
Thanks in advance for any ideas.
Izzy
Izzy
Texas
I know it is an early 80s motor. The PO rebuilt it before I bought it but I don't know the true health of the build. It seems to run nice and I really don't have any issues with it other than this tick.
70_Steve
Old Guy
Could it be pinging??? Try retarding the timing a couple degrees and see if the symptom changes any.
blubuckaroo
Grease Monkey
Ridgefield WA
Sounds like too much vacuum advance. When you push the throttle, you loose vacuum, and the timing isn't advanced as much and the ping goes away. For a test, disconnect the vacuum hose from the vacuum advance and plug it off for a test drive.
Izzy
Izzy
Texas
Which vacuum hose is the advance vacuum?
I do not notice any performance change when the tick occurs.
ITOWU2
close to Billings
I've got pretty much the same issue but I'm got an auto in mine and I can rev it up and hear it. I've been chasing it since last summer. this winter I did notice an exhaust leak around the header flange so I might have to check that. Sorry I can't really help you I'll let you know if I fix mine with fixing the exhaust leak.
Wes
TBS-POPS
valley springs, ca
You have pre-ignition knock or "ping". 1) run better gas, try premium instead of regular.or 2) retard timing a couple of degrees at a time till ping goes away.
Izzy
Izzy
Texas
That is an easy fix. I have to fill up daily so I will try that tomorrow. Should I try some more of the engine clean\lubricant stuff as well?
jw0747
San Antonio, TX
the hose attached to the distributor.
it's probably another case of the Bronco Hamster in the exhaust pipe. maybe not but I'd bet it's a broken or leaking exhaust manifold.
Izzy
Izzy
Texas
I hope these guys are right, my first thought was a rod knock under load? If it gets worse or louder you'll likely know...
Yeah I know. I hope you are wrong too. ;)
Of course, I am looking for a strong excuse to do a rebuild with a roller motor anyway. I just need to be pushed.
Izzy
Izzy
Texas
Ok, I am going to try the premium gas tomorrow but I did also find a exhaust leak so I will wait for this to cool and then see if I can tighten up the bolts. The leak is at the junction from the headers to the exhaust pipe.
Thanks for the help. I'll let you know how it goes tomorrow.
Izzy
Izzy
Texas
Update: I drive 80 per day to work round trip. I filled up with premium this morning and I also put in some of the engine cleaner stuff. The tick was much much better. I did still hear it a couple of times but it was 95% better. I'll run a few tanks of premium and see if it goes away completely. If not, I'll start playing with the advance.
Thanks for the help guys, I'm glad this was a easy fix, assuming it continues to get better.
Viperwolf1
electron whisperer
There's a simple spray solution.
