Tulsa76bronco
- Apr 23, 2013
- 591
Engine was running g great. Just had a lot of work on it, new parts coil, distributor spark plug wires, fixed wiring around the starter selonoid everything grounded properly and they got the alternator working. Took it out to try out the 4x4 drove 10 miles engine running great got to the woods and made it in 50 yards before it shut off? Started it back up started to go again and same. Flipped the gas tanks started again went off again started having smoke come through dash. Really hot, radiator boiling over to the over floor temp was around 200.
Maybe it was getting hot while driving it over there not sure. What should I check first buddy and I are thinking water sensor is bad or water pump not working properly
Any suggestions
Never could get it to fire up again even after it cooled down. It turns over fine but won't start. Gas flow maybe?
Any suggestions
