explorer engine w/3speed trans trouble
Rocko1012
Used flywheel and clutch assembly from 88 F150 Standard trans (Oreillys parts) Put trans and engine together twice. Could not turn engine once matted together.
Pull back apart to find Clutch disc housing is binding on bellhousing when fully together. Advice. Clutch assembly came with a help line phone number. I call and it was discussed I would have to grind down bellhousing to make clutch work. I did some grinding on area that is in pictures attached. See pictures
Anyone experience this.
3 Speed Ford stock trans and bellhousing.
Explorer engine.
Crush
Greenbottom, WV
Yep that is common when using the diaphragm pressure plate intead of the three finger type. When you order one from a bronco vendor it comes with those specific instructions
Redbark
I hope this isn't a thread hijack. I'm curious what flywheel you are running? There are many 50oz imbalance flywheels available (mustang, F150, later Bronco) that will work with the roller 5.0.
Other than 164 teeth on the ring gear, is there a specific 50oz flywheel to use is an early Bronco with an explorer 5.0 conversion?
I ask because I'm considering running an explorer 5.0 with an AX15 5 speed. I all ready have the AX15 trans and adapter plate for the stock Bronco bellhousing.
Generally most people use the full-size truck/Bronco flywheel from a 5.0 in the mid '90's. That's the style we sell.
You can't use the 351/5.8 version because it's still 28oz, but the 5.0 seems to be the same as our early ones, with proper offsets and such.
gick70
Yes,had this happen to me !! I cleared out the bell housing !!
R
Rocko1012
getting closer to having enough of the bellhousing ground down. Its not a flywheel issue, its the type of clutch design
