RnrdTheFox
I'm in the process of plumping my fuel system for an EFI setup. The main tank is an aftermarket 23 gal tank and the aux is the stock 8 gal. The main tank has two evaporative nipples, one of which will be used for the return. The aux tank only has one evaporative nipple, which I will use for the return line.
My question is this. Should I hook both tanks up with evaporative lines and run a charcoal canister or plug the second one in the main tank and call it good with the aux tank???? ?:?
If I want to hook up a second nipple on the aux tank, what's the best way to do that??? ?:?
Thanks for your help.
