bob_lafrentz
Higuys,
Has anyone ever popped a bearing off a Ford 9" axle?
Thanks.
Thanks.
Higuys,
Thanks.
I've replaced at least 5 outer axle brgs on Ford 9" rears that have "walked" out of the axle housing. Bad luck or design defect? Design defect, absolutely. Different housings, bearing size, didn't matter. I've seen at least 5 other Broncos in my community (only 14,000 including Univ. students) that have rolled or been in serious accidents due to failure of the axle and or brg.
BTW, it's time to change underwear when you look in your side mirror and see your entire tire/wheel outside of your wheelwell when you're cruising along with wife and kids in your rig! :-(
55 tons of pressure is way beyond what it should take to press it off. Chisel it or cut thru most of the way with a die grinder with cutoff wheel. Don't mess up the mounting surface on the axle at all. Put a dab of blue locktite on for a bit of extra security.
I went with a FF setup 6 years ago for safety reasons...never go back to a stock setup. Too EZ to fail.
Bad design? That's funny. Someone should write Currie, Moser, Strange, etc and tell them they messed up basing their business models on a poor/dangerous axle design with all of their custom setups.
If you're having axles walk out of the bearing retainers, there are probably other problems, either with the parts themselves or the installation/removal techniques. The only retainer issues I've seen or heard about until now were installed on used shafts with pitting and other issues from being beat for too many years and not well maintained.
