excessive oil blow by
wades76
Monroe, GA
I've got problem with oil coming out of the dipstick the oil filler hole and the pcv valve any ideas what could be causing this and how can I fix it. it only seems to happen when I'm driving I tried watching the engine while it was idling but I could't find or see anything. any help would be greatly appreciated.
Thanks,
Wade
67ster
Sounds like you are bulding crankcase pressure . The first suspect is the PCV valve , it's hose or the port where it enters the intake . Some models had a vented breather cap that can become plugged up with dirt , others had a hose from inside the aircleaner so the system had clean air . If all this checks out , perhaps worn rings and or valve guides are at fault .
wildbill
Old Bronco Guy
:p :p :p As was said if the PCV is all good time to look at a new motor good time to look at a 351W it is a good choice good luck. 8) 8) 8) Bill 8) ::) :p
Chief Master Sergeant
Retired U.S. Air Force
I had the same exact problem with a 74 I had. The problem is that you may have a PCV valve, which allows the engine to release air, but you don't have a place for the engine to take air in. At idle you wont have a problem, but when you drive and the pressure builds, it has to go somewhere and it's usually right out the top of the dipstick tube. I had to buy new valve covers with the holes in them already. For a quick fix we found a plastic oil filler cap and drilled a hole in it. We fit the cap with a brass fitting and ran hose from the cap to the air breather. Worked like a charm. Of course it didn't look cool, but then again, who cares. I hope this helps.
