Excessive crankcase blowby
Madgyver
Bronco Madman
Valve seals or piston rings?
I will have to pull motor to investigate.
Before I do, what other options do I have or what else can I check?
compression checks tops out at 150-160 all 8 cylinders.
oil on sparkplug threads.
sparkplugs changed and burns good.
oil all over transmission and under carriage, source of it looks to be the valve cover breathers or am I missing something?
loss of power on highway inclines.
Ran well after break-in.
once over heated. Motor is a year old so low miles.
intermittent white smoke out of exhaust through RPMs
I was going to get an oil catch can but that's just a band-aid fix.
smog heads on a 74 351W. smog ports plugged.
bulletpruf
San Antonio, TX
You don't need to pull the motor to investigate. Try a leakdown tester. That should help you diagnose.
White smoke with no smell is usually water; that could be a blown head gasket.
Do you have water in the oil? Oil in the water?
Madgyver
Madgyver
Bronco Madman
Recently changed oil, month ago and already black and very low so oil is going somewhere.
Hazegray
Could possibly be an intake gasket problem, sucking oil up from lifter valley and/or leaking out mating surface. Did you have the heads milled by chance when the rebuild happened? Rare, but sometimes you have to have the intake milled to match the amount removed from heads...
B RON CO
Statesville, NC
Hi, I agree with Hazegray, especially if you use an aluminum intake. I would pull the intake and take a close look at the gaskets between the lower intake port line and the valley.
Also you say your intake breathers seem to have blowby. Don't you have a PCV system? Do your valve covers have baffles?
The compression seems to be too good to have a ring or valve guide problem.
Good luck
ared77
And wouldn't valve seals be unlikely as they were new a year ago? Or could the "once over heated" situation have damaged the seals??
nvrstuk
PNW
Like already mentioned several times... leakdown first then intake gasket check... Overheated once can cause some major issues... how HOT is hot?
Simple easy check on your breathers being the exit point or not for some or more of your oil loss on your low mileage engine is to clean the area around both breather and PVC and them thoroughly so in a 5-10 min 3,000 rpm run you can then see if the valve covers are freshly covered with oil or not. Heads warping from too much heat sounds like what you might be thinking already?
That and the leakdown will give you some more clues to use...
phred
Earth
Hey Mad. Could be bad intake gasket. Mine did that after about 4 hours in a new engine. Aftermarket intake and iron heads. Pulled the heads and they check out fine. New head gaskets and intake gasket and the problem never reoccurred.
WheelHorse
Overheated...how bad? May have glazed the cylinders or stuck a few rings.
Buy a vac/pressure gauge. I had one from Craftsman where you could unplug the breather...place the conical adapter into the hole and push it tight (would have to hold it in place) and rev the engine...you'd watch the crankcase pressurize. Engine was shot.
Only way I know, to figure out the why, is a true leak down test. Listen where the air is leaking out of it and the percentage leak down.
Quick cheats if it's rings...Engine Restore in a bottle. Only stuff I have heard from old mechanics that works. Honey stuff is crap yada yada, but Restore will bandaid it until the funds allow for a teardown, break the glaze, thorough hot soapy water wash and a new set properly gapped rings if everything else is in spec.
Readhead
I’m running a 302 so I’m not sure if this applies to a 351 .
There is an early and late model intake gasket on a 302 maybe a 351 guru could chime in and answer that question
Madgyver
Madgyver
Bronco Madman
I got Taz to pull the intake again and this time he found this.... see pics.
Intake and exhaust rockers for #1 cylinder were out of place. I could see how it bounded up. Exhaust rocker retaining locknut came off and was sitting on the head. Other nut was still on stud but loose.
We will get this fixed first and then go from there.
Taz did mention to me a slight drop in oil pressure.
Rustytruck
the only time I've seen push rods like that was bad valve adjustment on start up and a friend who bought a set of used rebuilt heads and slapped them on the engine and tried to start it, all the push rods bent on one side of the engine. there was no lubricant on the valve stems and minor surface rust stuck the valves tight. A full disassemble was an expensive lesson, push down on those 2 valves and make sure they are free.
73azbronco
Interesting how you got the newly designed curved push rod to work on the older motor:)
