73EXP
OK- so now I am researching dynaflow vs. dynamax vs. magnaflow to cut the NOISE... my next question is:
exhaust pipe ends, I have looked at turn-downs, to try and stop the (dual) exhaust from coming right back into the back of the truck when the top is off, but what about those deflectors?? anyone have those? the ends are made as though they left a crossways diamond of metal on top of the end of the pipe, and then bent the corners down to send the fumes out, and away from the vehicle.. is this a satisfactory solution to the problem of exhaust that normal would return with the air rushing under the truck that sends the fumes back into the rear cargo area?
thanks again-
A
thanks again-
A
