Exhaust Donut
Rickb1b
Got a 351w in a 69. I used the old 302 exhaust l manifolds, which requires the use of exhaust donut type gaskets between the manifold and exhaust pipe. Problem is mine keeps disintegrating and causing a major leak. I’ve replaced them at least three times in the last 1000 miles.
So question is; what are you guys using for this connection. The NAPA exhaust donuts don’t seem to be working.
73azbronco
Is the exhaust pipe correct, does it have the pipe part that goes into the doughnut? That should keep it all together. Only way to disintegrate is for exhaust to be moving around. A lot. Unless the gaskets are crap, which would not surprise me.
Probably a problem with the exhaust being supported correctly. If the exhaust isn't supported close to the engine it can shake around and eat the doughnuts. But if the exhaust is supported too close (and too solidly) the exhaust will be trying to anchor down the engine as it moves around on the mounts.
migs
I had the same issue after installing the James Duff dual exhaust kit with the optional down pipes to adapt to the stock manifolds. they only have an open flare on the end, no inner pipe protruding from the end to fit inside the doughnut like the factory pipes.
plus the passenger side didn't quite line up square and the system mounts a little too rigid to the frame, so combine that with hot gasses passing directly over the type of doughnut they provided and they wouldn't last more than a day for me.
see below...
I was able to locate one solid steel doughnut in my parts stash to use on that side and also cut some pieces of tubing to slip inside the both the steel doughnut and the compressible one left on the drivers side for good measure.
I did all that the day before I left for the bronco round up back in june and it's holding up so far.
R
Rickb1b
Migs, that’s exactly what I have going on. I’ll try the pipe insert. Just curious did these originally have some sort of steel insert. Because mine just has a flange in the exhaust pipe which mates to the exhaust manifold. I had the system built at a local exhaust shop and it’s just how they did it.
migs
It seems like most of the old factory looking pipes I've removed from broncos had the flare formed near the end of the pipe by expanding and compressing the material over itself forming the flare and leaving a bit of pipe on the end for the doughnut to slide over.
I think the single flared open end is much more common nowadays as I'm sure it's cheaper and easier.
I did go to the local auto parts stores that day before the trip to try to find something that wouldn't burn up... but that was pretty much useless without the year, make and model....%)
ENDLIFE
First off, I have never seen a exhaust donut used on that type of flare. On that type, I have only seen it used in a ball to flare connection. If you want to use an exhaust donut (which I love), you will need a tube stop bead on you pipe connection, however, a lot of exhaust shops do not have the tools to do them anymore. I had to TIG some metal rings from Home Depot around some 2” exhaust tube many of times, and it works just as good as the beading if done right.
This is what you need for an exhaust donut.
R
Rickb1b
Guess I shouldn’t be surprised my exhaust shop screwed it up. Had to take it back twice because the drive shaft kept hitting the exhaust pipe. Thanks for the input guys. I now know what needs to be done.
R
Rickb1b
Endlife I like what you’re saying. I am going to try and do this to mine. Can you be more specific on where I get the rings. What section of the store would I find them. Never seen anything like it in Home Depot.
migs
If you weld a flat ring on just be careful of what type of doughnut you use, I would want something more like in this first picture... something with a solid flat end that the ring would push against and compress the tapered end into the exhaust manifold.
The squishable lead like doughnuts I showed above are tapered on both sides and work best with a flare on both sides to help crush it around the pipe it should be sitting on.
also, here are some pictures of an old original I pulled off. the double angle steel doughnut is rusted in place but you can see the angle of the flare, it was formed in place and seats against the doughnut properly.
Before you go cutting your ends off and welding on rings maybe give it a try with inserting the pipe sleeve inside the double taper doughnut first.
cheap and easy to do. You can see that the length of it should be a little longer than the doughnut. one end should bottom inside the exhaust pipe flare, and the other end should protrude slightly past the doughnut.
Nevadasmith
Fallon, Nv
I just went through this with my i6, I made a new down pipe, with a flare, then I found a tube I could press in that was 1/8" longer than the doughnut, 1000 miles so far no blown out doughnuts, I was getting 150 miles to the doughnut!!! Hopefully that helps
Cooter_76
Are your motor mounts in good shape? I went through this years ago, only to find out a busted motor mount was the culprit.
ENDLIFE
Here are the ones I use in the past. They are nickel plated, so you don't have to worry about contamination from an incompatible metal.
https://www.homedepot.com/p/Crown-Bolt-1-4-in-x-2-in-Nickel-Plated-Ring-64904/203001538?MERCH=REC-_-PIPHorizontal2_rr-_-205883057-_-203001538-_-N
gick70
I had the same problem,went with a steel donut,no composite,or poured metal one!
R
Rickb1b
Thanks for all the input guys. Here’s what I did. I think it’ll work.
bigjhoov
nobody
I just went through this on a 200, kept blowing out donut gaskets and couldn't figure out why. Kept looking at new exhaust systems and noticed the bubble flare on the down pipe, mine just had a flare. I cut a liner pipe out of some 2" for the donut to have something to crush against, been good ever since.
