If the only change to the suspension from stock is longer radius arms, the ride will be slightly smoother because the front wheels are moving through less of an arc, and more of a straight line, which puts less of the impact on the frame. The tiny increase in unsprung weight isn't significant because it's at the small, non-moving end of the radius arms.
If you've decreased the caster angle by lifting the suspension incorrectly, swapping to longer arms alone will return a TINY bit of caster. But there are cheaper & more-effective ways of adjusting caster, like changing the C-bushings, or cutting & welding the wedges on the axle tubes, or installing drop brackets on the frame for stock-length radius arms.
