Explorer 4R70W Questions
snick
Awhile back I purchased a 1996 5.0 explorer AWD donor with 250+ miles. Recently I found a super cheap much lower mile 1999 5.0 explorer with a RWD 4R70W with the improved internals. I’m going to bolt either a NP205 or atlas II directly to the AWD tail housing from the 96 explorer.
1. To install the AWD housing and rear shaft from 96 to the 99 4R70W, do I have to open up the transmission?
2. Is there anything that’s not compatible/needs to be modified/etc with installing the 96 AWD tail housing and rear shaft or anything else onto the back of the 99 4R70W.
I plan on using the the EFI harness and 4R70w tranny harness from the 99 so the plug connections will all match up.
Thanks in advance
1) yes. The output shaft installs only from the front.
2) should go right in.
