Explorer 5.0 stock replacement front exhaust pipes with CATs and O2 sensors - will they work? UPDATED 11/17/24
skrit
skrit
A Horse with No Name
Durham
Trying to keep the 5.0 swap as stock as possible in my EB which means I want to use the O2 sensors and CATs without deleting them and having to reprogram the PCM. Below is a stock diagram
What I'm interested in using is the the left and right cat pipes from my stock explorer manifolds. All the exhaust behind it will be custom. Could an exhaust shop duplicate the O2 sensor locations relative to some universal CATs and just do a complete custom job without messing up what the PCM expects to see?
OK - So I'm back at this. The driver side works fine without mods other than cutting off the welded rear flange. The passenger side needed some mods. I cut and taped it up to mock it up.
I think this will work if I get it welded up. What do ya'll think?
Now the Explorer 5.0 had a "rear" double cat with no rearward O2 sensors so I think this was just to further polish the exhaust fumes. Should I add these anyway? I don't think that rear cats did anything with the 5.0L PCM. I plan to put some heat shielding around the front cats to protect the tranny and frame. I'll cut off the welded flange end of the drivers side and tie these 2 cat outputs which are 2.25" OD into a 2-into-1 muffler and extend a 2.5" OD to a resonator or maybe not do the resonator and go straight to the tail pipe. If the cut on the welded flange is too close to the existing O2 bung, I'll use one of these clamp style O2 sensor adapters.
Instead of a 2-into-1 muffler, maybe I use a Y-pipe instead and use a 1 to 1 muffler? I'm looking for a quiet exhaust system. Thoughts are much appreciated. It won't be easy just to take this down to the muffler shop and have them fab something up.
skrit
skrit
Durham
On a side note...I see the Duff's Dominator long tube headers work with GT40P heads AND the 4R70W. While I would love to have these - it's not in the cards but I am interested if anyone has used them in a 5.0L swap.
