- Oct 11, 2007
- 405
Have a question for any of you guys that have the done explorer rear disks. I’ve searched around and can’t find any info on this. According to Currie, in order to use the explorer setup i have to install a spacer ring on the axle. They are using the set 20 bearings in the video on their website. My question is do I have to use the set 20 bearings or can I keep the sealed bearings? My inderstanding is in order to use the set20 bearings I also have to change the rear axles as the original axles are a different diameter and won’t accept the set20 bearings. I do want to put new 31 spline axles in eventually and will go to this bearing style but a complete axle and carrier upgrade isn’t in the cards right now. Just trying to see if I can go ahead with the explorer brakes or will I have to wait until I can upgrade the axle shafts.
