Do you use the light part of it as your indicator for overdrive off/on? I was thinking I would need that NO set of contacts for the indicator light to illuminate when I switch it off.
I made my own metal lines, then I have a short sections of braided to the intake and return lines to the fuel rail.
Those fittings and braided are the most expensive parts next to the fuel pump!
Did you get your fuel pump and your regulator figured out yet?
I have a preformed rubber tube attached to my oil filler tube. I'm assuming this was inserted into the air intake. Can anyone tell me if this is necessary and if I'm correct in assuming it was inserted into the air intake tube? I'm having to fabricate my air intake and can't make up my to make provisions for the tube or discard it, thanks for you help.
Ralph
Keep the tube, it runs from the nipple on the oil fill to the air intake. It needs to be mounted between the MAF sensor and the throttle body.
It is the fresh air inlet to the crankcase for the PCV system.
