Explorer EFI Mass Buy Feeler.
airbur
Castle Pines, CO
I just want to say that I took delivery of my ECU and Harness from Garry...
It is very clean, sano job, all the Ford connections are marked along with the individual wires and he supplied the Explore relay box with the rewire.
Garry called me with a lot of questions and he has provided me with the wires in the locations that I need to work with my 68 and the Centech harness.
The harnesses (3) (engine, 4R70W, and power) have fresh wire loom and are prewrapped with tape. I feel the quality is as good as I would do, and I am very type A about how I do things.
I am eager to get started on my rig, but it is at the body shop and when it comes home I will need to pull the 289 and 3 speed, then clean and paint the frame before I can get started.
Garry is awesome!
EFI Guy
EFI Guy
TheEFIguy@gmail
BFE
Thanks guys!
I'm glad you like it! If you can decipher my serial killer like handwriting then your install should be a breeze. I'm looking forward to seeing it action, do you have a build thread Doug?
904Bronco
San Martin, CA
Thanks guys!
Not really... I did my 77 on www.norcalbroncos.com under Project broncos: "My new Bronco"
I have a lot of pictures of my 68, but I have not started a thread anywhere yet... busy with other stuff and kids activities. I will be shooting you a quick e-mail with a few small questions... ;D
Doug
Goochland, VA
What is the next step? I need shipping info. Do you need vehicle specs, engine specs, and other modifications? Payment terms: deposit, full up-front?
EFI Guy
EFI Guy
TheEFIguy@gmail
BFE
Just PM me with your e-mail address. I'll send you an order form to fill out all of the specs, and give you the shipping address.
Bronco73
Cape Coral, FL
Today was my lucky day. I thought I had given all my mountaineer wiring and computers away when I sold a project EB I had. Turns out I had two engine harnesses sitting tucked away in the over head shelve I have built in the garage. I only have one computer. The wiring I don't have is for the auto trans which I do not need and I need to go look for the fuse box and relay stuff. Not sure if I have that.
As soon as funds permit I will go the explorer EFI route as I have fuel rails and all to run this set up.
I do need to figure out which harness goes with the computer. One harness has the 3 wire dizzy hook up and the other has a 2 wire hook up.
EFI Guy
EFI Guy
TheEFIguy@gmail
BFE
If you can tell me the code on your PCM I can tell you which cam sensor it uses.
Bronco73
Cape Coral, FL
You da man EFI Guy. When I get the money I will be having you perform the work and thanks for answering all my other past questions.
igottastanger
Definately put me on the list for round 2. Ive already got my 96 explorer torn apart and sent off the the salvage yard. Traded for an old horse i didnt want anymore and got the complete 96 explorer running with the title. Tore it apart kept the entire drivetrain pulled all the harness out from the engine compartment and the obdII as far back as i could. Kept the computer and will want to run the 4r behind the motor. The best part is that i got $275 back when i scrapped the body. Not a bad beal. So im definately up for this just need more details such as pricing and anything else you might need on your side.
stickbnder
interested in one also
i am in for one also. i have a high end build im getting going on. so im in no hurry. but i will need everything (computer harness etc) i have a 95 351w mild build with 4r70w. nothing to crazy. but would like to use my billet dizzy.
EFI Guy
EFI Guy
TheEFIguy@gmail
BFE
Well guys, I'm not doing the Mass buy thing any more, sorry.
Instead, I'm just taking orders as they come in at the mass buy price.:)
You guys have been keeping me busy enough that getting 5 at a time is not an issue any more. I'll keep the price the same through the end of the year for sure. There has been some hinting that my tuning costs may rise after that.
I'm a couple of weeks backlogged, but any body that wants one done just PM me with your e-mail address. I'll send you an order form and shipping info.
EFI Guy
EFI Guy
TheEFIguy@gmail
BFE
There is no way to run a dizzy with Explorer EFI. You will need a cam sensor and coil packs instead. The EDIS system is far more accurate and reliable than a distributor anyway.
I still haven't gotten around to trying the hybrid sensor for 351w use. I know several people have had collars made to use the 3.8 sensor.
Anybody want to chime in as to who is selling the collars?
Bronco73
Cape Coral, FL
Good to know. I hope to have the funds here shortly to have my harness reworked by ya. I first have to go get the bulk head connector I am missing from the pull it yard next week.
lars
Been here awhile
NorCal flatlands
Sent you a PM.
EFI Guy
EFI Guy
TheEFIguy@gmail
BFE
Well guys, A big huge thanks goes out to Lars!
He was kind enough to share his R&D work on the 351 collars with me. I'm going to have one of my machinist buddies make one for me. I suspect I can get one of the local guys here to try it out.
If all goes well I'll see if he's interested in making more.
stickbnder
i am interested in 351w setup. i will need pretty much everything. how am i looking at? i have the intakes, injectors. need all electronics.
