Explorer front facing Coyote style intake Pole
Would you purchase
  • Total voters
    10
duffymahoney
I am gauging interest for a coyote style forward facing/ long runner intake for an Explorer 5.0 or anyone running EDIS on a 302. There has to be enough of us for any company to spend the effort making an intake for a older motor. Holley had an engineer call and chat with me about it. They seemed interested. Please take the poll if you are interested.
Here are the basic facts that I sent to Holley and Edlebroke.
The classic bronco, F100 truck, ranger and mustang world is sort of stuck when it comes to an EFI motor that fits. The coyote motor doesn't fit (too wide) without a ton of work and is very expensive, bronco guys basically figure it’s a 10k install. The 5.0 out of mustangs fits great (getting rare and expensive), but the intake direction takes up the whole engine bay. Also makes it so you can't easily do things like check the oil easily, brake booster etc.. Just a giant pain to work around and looks terrible. Now the big swap is 5.0 (302) with EDIS and or the ford explorer 5.0. Which means no distributor.
Ford having front of the motor distributor is why the intakes are off to the side, but now without the distributor it's something that is a none issue. I believe, and I think the market thinks it's time for someone to design a forward facing intake with long equal length runners like the LS motors and the coyote. Basically a clean, smaller package 5.0.
The reason the 1996-2002 Explorer 5.0 is so popular is that it bolts directly in, Ford made a ton of them, so they are everywhere and cheap. They fit nicely and aren’t wide. The heads flow well, simple valve train, lots of aftermarket part support. Also the Ecu is OBDII so you can actually use it to troubleshoot issues. The front dress, fan and accessories for the explorer is the preferred front dress of anyone in the bronco/ mustang world. It’s shorter, bolts on any 302 block and are made from nice cast aluminum.
The intake would need
The same fox/ explorer throttle body mounts
Explorer or fox injector location/ Fuel rail
Same basic overall height or shorter
Vacuum ports, at least 2
Visually appealing
Long runner (11"- 13")
Probably 2 parts, either cast aluminum or plastic
PCV valve
Coil pack mounts or perhaps coil packs on the valve covers
Coolant passages
Cost Effective
Thanks!
sykanr0ng
Two thoughts:
1) If it is made two piece could the top be turned to face the rear?
Would it be possible to turn it if it was one piece?
There is more height there and a cowl induction would be easier to make with the intake facing that direction.
2) There is an even greater scarcity of a good intake for the 351W, could the same design be made for the taller block?
The Lightning / marine intake is harder to find and much more expensive than the Explorer intake, yet the 351W is a popular engine swap option.
D
duffymahoney
Two thoughts:
Front induction looks the coolest to me. It wouldn't be able to turn, it will be directional.
351 intake was talked about. I think the 5.0 would have to be first, since it's the most popular.
pcf_mark
I like how your mind works - old 5.0 stuff is leaving something on the table. A long runner plastic intake could boost torque and aid with hot re-starts.
But I am slow to go front facing with the Bronco radiator support package. The OEMs go forward then up and over the radiator in a lot installations today. With out trucks that is not an option. If you go forward then flip left or right could package the air filter and get outside air to a box on one side or the other. Not sure if that is ideal but at least the intake elbow can be massive to avoid a restriction. Cool idea.
I would be in for $500 or less. Probably not enough $$$ in it but low cost nylon manifold is a thing.
D
duffymahoney
I think the air intake elbow would have to be like the coyote. Basically sharp turn right out of the intake and towards the drivers side.
I like the look, but also I think there will still be clearance issues galore. But since you have the setup I'm guessing you've looked at it and think there's a possible routing for the intake already.
Do you think it's going to fit without the need for a taller body lift, and/or a taller hood?
With the Explorer stuff you'd obviously need to factor in the alternative mounting location for the coil packs, and different plug wires for certain, which you already mentioned. Likely would indicate at least a slight re-work of the main engine wiring harness too. Probably not a big deal.
Could be as simple as a jumper harness included with the kit, as long as a set location was found for the coil packs.
With the new design, you can get the light weight and temperature control of the synthetic materials vs aluminum. So that's good.
To get equal length runners is likely easier, and might be able to get them close to the stock Explorer runner length with more of a dome top (more like an LS than Coyote?) but clearance in the center is not as bad as it will be up front where the TB is going to be.
I figure lengths of approx. 13"-14" (not including the intake port) for a stock Explorer intake and heads. Sound about right? If so, I can see this new intake as a higher rpm replacement, but not sure about a low-rpm enhancer unless the equal lengths and new materials are that much better at producing broad power.
If the new ones are at least the same length, do you think there will be a notable performance benefit from the slightly more equal length of the runners? More clearance on top and left side? Or is it going to be mostly for the looks, or perhaps greater higher rpm breathing?
We don't have the long intake ports of those heads either, so additional length needs to be all in the manifold. Our V engines are not as widely spaced as a Coyote, or as deeply Vee'd as an LS block, so any additional runner length is going to be upwardly vertical.
Maybe the designers can come up with an intake that runs down deep into the lifter valley with a full heat-shield. Or maybe the heat shield is not necessary with the resin based materials?
I may be thinking on the wrong side of the box, but seems to me the clearance issues still start to stack up everywhere under a Bronco hood.
Thinking of the power steering part of the driver's side bracket, which would likely limit your driver's side location of the MAF sensor and air cleaner. We already lower the tank for hood clearance, but could the main bracket be cut down and still fit the pump too? Or is that not an issue with the pump being there from what you can see?
Seems like the 90° turn might end up being more like 150° instead.
What about the MAF location? Will the filter be hanging out into the driver's side over the exhaust and steering, with no facility for a cold-air and turbulence-control design?
Or are you thinking about the MAF right on the TB?
Going to need some special tuning of the ECM I would think, or some re-thinking of the hardware design.
Have you PM'd EFIGuy to see if he's got some input on this? I bet he's worked with them enough to know what's easy, what's possible, and what's best to avoid.
Water outlet with thermostat and upper radiator hose would need to be taken into account as well if any thought of going to the passenger's side.
Pretty sure we can't go back to the old lower profile style t-stat housing because of the Explorer bracket.
Alternator is totally fixed and non-negotiable on the passenger side of course, so any radiator hose re-location or intake tract re-routing would be sharing space there too.
And all this going on at a lowest point of the hood.
After exiting the TB the tubing might have to go oval shaped instead of round before it rounds out again for the MAF sensor.
Or were you thinking of the air filter right there up front on a short elbow?
Might not work that way on a Ford MAF setup, but I don't know that for a fact. Just conjecture.
I'm actually likin' the whole modern look too in spite of how I'm sounding, but we do actually have reasonably long runners in our EFI intakes already.
I just think that we're going to run into the same packaging issues we always have. Low hood on a short engine compartment, with lots of additional stuff up high with the Explorer front accessory drive.
D
duffymahoney
Paul[/QUOTE]
You like to write novels:) I think you have a couple very good points. Especially about the ps pump.
The runners would have to connect directly to the heads for the needed length. The idea would for it to be shorter (neater) then the explorer stuff. But with the same basic length/ volume runners. This could be impossible. But looking at a coyote intake next to a 5.0, it seems very doable. This is purely a guess though. The runners should go into the valley. So lots of room.
The intake would have a lot of thought put into it. Like you said, lots of things to clear with not a ton of room, but I think it's doable. My idea would to have the intake done just like the coyote swaps.
Looking at my setup, really the only easy way would be to do a delphi saginaw pump (wildhorses). There is almost enough room for it to go on the passenger side. All I have was 3" pipe to test fit, and it was too big. The mustang stuff is 2.77". Which I will test later if I can find my box of intake tubing.
Maf would need to be by the filter just like the coyote. You can buy just about any shape and size intake tubing for cheap. So I am not really worried about that aspect.
COP or Coil On Plug is pretty difficult with the explorer/ edis stuff. Since it's all 2 wire coils. Not a lot of options. I would most likely hide or mount the explorer coils somewhere out of sight.
Biggest hurdle will be getting someone to want to make it. So far we have about 50 people that are interested. Which isn't enough.
