Green_Bastard
- Jan 4, 2014
- 257
Hey guys,
so I'm about done with my full restore that includes the Explorer EFI conversion as well as LED lights on all corners. I noticed that after hooking everything up my taillights are on. After tracking through the harness, I found that the power is coming from pin 4 on the C115 plug from the Explorer harness. This is the red/green wire that goes to the brake light switch and should be hot when pressing the brakes. I checked the voltage and it looks to be between 5 and 6 volts coming through it. If I swap out the LEDs for traditional bulbs, its not enough voltage to light them up. I've doublechecked to verify its not shoring across with another power source.
My question is, should there be any voltage on that wire coming from the computer? Can someone check theirs to see if anything voltage is coming through?
