Small bearing 9" with factory limited slip. Installed 4.11 gears, new 28 spline axles and replaced bearings throughout. Installing rear disc setup off of a 96 explorer. Two issues. The axle bearings are about .15" thicker than the landing in bearing housing, so they stick out beyond the end of the housing. Second is offset. I have read about a million posts and threads on here trying to figure out what I need to do to my setup to make it work. Seems to need about 3/10" more offset for the disc to be seated on the flange. Ground the housing ends and the caliper mount fits flush. 'Lil help?
