- Jun 13, 2007
- 1,832
So, I am trying to get my Bronco back on its feet (so to speak). Winter upgrade includes Torino axle housing, 31 spline locker, Yukon axle shafts, R&P and Explorer disc brakes.
The housing is in the truck and center section bolted up. I bought the Currie spacers and installed them on the axle shafts prior to pressing the set 20 bearings on. When I slide the axle shafts in, the spacer sticks out proud of the backing plate by .150" or so. Seems way to much to squeeze the bearing when I bolt up the retaining plates.
I understand the purpose of the Currie spacer is to account for the difference in thickness. My original drum plate (small bearing 28 spline) measures .115" thick. I assume a medium duty drum plate is the same thickness but can't say for sure. The Explorer disc bracket measures .285". that makes for a difference of .170". What I don't understand is why the Currie piece is .235"?
Calls to Currie haven't shed much light on the situation. Only got a "guarantee" that it would work fine...
any body help shed light on the situation? I have done some searching on this site as well but not finding much...
