I have a few questions on the Explorer serp setup and thought I'd run them up the flag pole of opinion....
Explorer fan...metal or plastic? Anyone know if one flows more air than the other? Have 1 of each...is one better than the other?
Distributor stabbing "sweet spot" is addressed in the tech article. I forgot to clearance the back side of my drivers side bracket for the TFI plug clearance. The tech article mentions a sweet spot that still allows enough adjustment to set timing without grinding the bracket. Is that "sweet spot" with the TFI plug behind the idler pulley, or between the idler pulley and water neck?
EFI coil bracket....other than the home made one in the tech article, has anyone come up with one that works well? I may have found one that will work well as an "almost bolt on" but I'll keep this thread updated with the final verdict. It's from a ~late 80's Aerostar. It's on the back side of the engine & is reached by removing the access panel inside the passenger compartment.
