Explorer Serp Set up-Timing marker
Banjer Picker
For you guys with the Explorer serp setup, how do you determine where to put the timing pointer and where to place the TDC mark on the pully? I want to put my serp set up on after the OCBR event but I'm worried I'll get it installed and then have no refernce point for setting the timing.
Also, what electric fuel pump do you recomend?
Thanks!
recoiljunky
Dothan, AL. USA
Timing pointer goes on the passenger side of the timing chain cover, at about the 10:00 position as facing the front of the motor. I used a stock explorer dampener that already had the marks in the correct place.
I think you also have to get a specialty pointer, one designed for an explorer motor. I googled "explorer crank position sensor pointer" or something like that to find an online source. The pointer goes where the crank position sensor used to go.
Banjer Picker
Banjer Picker
I plan on using the factory explorerdampner as well.So I'll I need is that special pointer and it will work on my '73 302?
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
You don't need no stinkin' fancy factory pointer. Just make one for pete's sake. Find top dead center on no. 1 cylinder. Observe where the slot is on the outside of the Ex balancer. Bend a piece of sheet metal shaped like a pointer to point to that spot. You will of course have made one out of cardboard beforehand as a mock-up.
MarsChariot
Planetary Offroader
See this here pointer. It was just a comon ordinary piece of aircraft aluminum off the bombbay of a B-52 that got cross-wise with a sidewinder and crashed into a cinder cone. Somebody picked up that nice piece of aluminum and shaped it into a timing pointer.
Viperwolf1
electron whisperer
That pointer is the bomb. ;D
recoiljunky
Dothan, AL. USA
Yeah, well not everyone has B-52 parts just laying around everywhere. Some of us find it easier to spend $20 and have the brown truck deliver the pointer to our door. ;)
Banjer Picker
Banjer Picker
A WW II plane, huh...Now thats a pretty interseting "doner vehicle" to pull a part from.;D
Sounds easy enough....now how do I determide TDC on Cyl 1?
mattt
I don't know if all Explorer crank position sensors have this or not, but my stock Explorer CPS has a pointer on it. I've seen this question come up regularly, and always wondered why not use the stock piece?
Smokeater11
Auburndale,FL
Wooooh Nelly!!!! You're planning to use the explorer dampner on your 1973 302 motor? Someone correct me if I'm wrong but wouldn't the donor Explorer be a 50oz imbalance motor and a '73 302 be a 28oz imbalance motor. If so, that balancer shouldn't work!! I have never delved into the whole serpentine world but I know it won't work the other way around(the older balancers on the newer motors). Hopefully someone with more specific knowledge will chime in here and know for sure. I know for a fact that the flywheels/flexplates aren't the same imbalance but I'm not 100% sure about the harmonic balancers.
As far as finding TDC, the way I've always done it is to pull the #1 plug and stick my finger into or over the plug hole to seal it off and then have someone bump the ignition over until I could feel the compression start to build. Then I stick a 6'' socket extension in the hole and turn the motor over by hand(using a socket on the crank pulley bolt) until the extension stops rising. You should be able to find the area where you're turning the motor but the extension isn't moving upward but hasn't started to move downward yet either. That's TDC. But it imperative that you do this on the compression stroke or your timing mark will be 180* off on the pulley and you'll never be able to set your timing properly.
Viperwolf1
electron whisperer
Smoke is 100% correct about the balance issue. Balancer needs to match crankshaft and flywheel/flexplate. A machine shop can re-balance the balancer or you can use the pulley available at Driven Auto. Another thing to take into account is the explorer timing cover must be used as well.
Smokeater11
Auburndale,FL
Sorry buddy:(, but it'd better to find out now then after you've put it all on, discovered the wicked vibration, and have to take it all back off. At least now you know and can get everything you need ready and only have to do it once.
BTW, it's really nice to be right about something for a change.:cool:
Banjer Picker
Banjer Picker
Hey gentlemen, really do appreciate the warning/ panic but I'm way past the 28 oz vs 50 oz imbalence issue with the explorerer dampner/pulley....I'm not BRAND new ya know? ;D;D
(Now if yer talking about FL football and imbalance, well I dont know where to begin or if there IS a fix. Paaaaaaaaaaaaaaaaaa! Sorry Mark.)
I understand the need for a properly ballanced crank pulley, my fear is getting it all together and not being able to determine how to set the timing appropriately...cause its also about time for a tune up.
Just trying to reach out to see if there was a technical way to determine TDC after a non-OEM pulley was installed.
PS..Mark I'm going to send some that Shiner Bohemian Black back with Franko if he doesn't mind and has the room. I enjoyed one...err...8 of them out on the lake tonight and...well... I'm no beer snob (hell i drink PBR, Lone Star and Pearl light) but that Shiner B.B. is just plain good stuff!
mattt
If you're using the factory explorer dampner, I suppose you had it rebalanced by Damper Dudes or the like? The factory dampner has timing marks on it, and I believe TDC is referenced on it. If it's just the pointer you don't have, check a local junkyard. They are pretty much a dime a dozen in my area.
Asking again....why have some people made a pointer when the factory one is there? Did you not get the factory pointer when you picked up the whole enchilada? I suppose if you didn't pull it yourself from the donor vehicle, then maybe you don't have the factory one. Every so often I hit the local yards and could grab a few of the stock Explorer CPS/timing pointers if the need exists?
stretch
Montgomery, TX
Since I don't have any spare B-52 parts laying around, I was wondering if anyone had a extra Exploder CPS with the timing pointer. I've seemed to misplace mine.
Smokeater11
Auburndale,FL
That would be awesome bro!! Just make sure you tape the box shut so Franko doesn't drink all my beer!!;) I'm so excited!!!!
P.S. I know that FL football comment had to have come from your wife:p All I have to say to her is SCOREBOARD!!!
Now back to your regularly scheduled programming.......
lonesouth
You can get the factory timing pointer from your local Ford parts desk for less than $20. They also have new PS resevior for ~$25. At least they did 4 years back.
