Explorer Serp with Large cap dizzy
Dbarnes72
Eastern Wa.
Just installed the Explorer serp and think I see clearance trouble on the horizon with the Skip White large cap distributor. The engine is at TDC on #1. This is the only spot I could get it to drop in. If the distributor rotates CCW to get it to time, I think I'll be okay. If it goes CW, it's already touching on the thermostat housing. Any ideas?
Phil76
Aransas Pass, TX
You could remove the distributor and turn the oil pump using either a priming tool, or loooong 1/4" extension. Doesn't need to be much. The try to re-stab it a little more to the right. This should give you more room for timing adjustment. Most timing adjustment is made clockwise.
lonesouth
the 302 can point to the drivers fender between the head and the PS bracket. May need to grind. I would restab at whatever position allows you to have the correct timing. It is a huge PITA. You may also find a vac canister that is smaller than the one you have. I picked up a reman dizzy and the vac was a good 1/2" larger diameter than my stock one.
Dbarnes72
Dbarnes72
Eastern Wa.
Good suggestions, good lessons. I was thinking that the position was indexed off of the cam. I'll get a tool and turn it.
