I am accumulating parts to install the Explorer serpentine setup on my stock 77 motor and need guidance on the best way to eliminate the fuel pump eccentric cam behind the timing chain cover. I have not opened up the timing cover yet and would like to have the right parts on hand. I am assuming the stock washer on the retainer bolt is not large enough in diameter to retain the timing gear, and the alignment pin will be too long. What parts will I need to accomplish this, and is there any concern about endplay or preload on the cam on a 30k mile stock motor? Any help would be appreciated.
