Hello all,
I have a 76, 2001 Explorer swap, EFI Guy harness, that's getting pretty close to being done.
My engine only runs for about 5-10 seconds, and then it dies. It's either a fuel pressure issue or a lack of an exhaust issue. My fuel system is a 23 gallon tank, with the fuel pump inside the tank. I am running a supply and return line. I put a 96 Explorer fuel rail on the engine, because I wanted to use a in rail fuel pressure regulator. I get 65 psi of pressure when I test the fuel rail pressure.
The only computer mods I have had done are PATS delete. I kept the stock EGR and emission ECM programming functions, they weren't deleted.
I do get a 3 second fuel pump activation from the in tank pump when I turn the key, and the motor does fire up, but it dies after a few seconds. I can't tell if it's dying because it's losing fuel pressure or if it's because it has no exhaust system on it other than headers, and having no O2 sensor data getting back to the ECM.
I would think that at worse case, the ECM would still be able to keep the engine running in limp mode, without any O2 sensor data, but I'm not sure.
Also, if the problem isn't exhaust related, do I need to have my ECM reprogrammed to not look for the stock in tank fuel pressure sensor, or hace any code written to have the computer always keep the fuel pump on?
Thank you all for your thoughts. Mel
