Explorer throttle cable firewall
Big Slim
I am seeing what or if others had this problem and how they fixed it. If I want to put the cable in the stock location the cable is hitting the manifold. Would be a tight bend that I think the cable will not do. It has a 2” body lift maybe making it to high to go under the manifold. I can’t put it to the drivers side since inside the cab there is a support bracket in the way holding the pedals. Was thinking maybe going above the manifold but the the pedal ratio would be off making it very sensitive pedal. If I somehow get it to attach angles the the pedal would be pulling the cable angled which wouldn’t work great.
Rustytruck
Bc broncos had a fix for this and Viperwolf did some work on this and their was also a ratio change to make the throttle work more smoothly. gotta start searching our archive.
Big Slim
Big Slim
ok. i have modified the throttle body and made a bracket for all of that to align properly with the explorer cable. just need help with manifold/cable interference going into the cab.
