Explorer timing chain covers corroded on
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Anyone else have an issue with pulling Explorer timing chain covers at the local yards? Today, for the third time, the upper outermost bolts holding the cover on are corroded to the block and cover. The heads snap off when pulling the water pump, and the cover ends up damaged in one way or another when trying to get the corroded bolts out.
Anyone else have this issue? You'd think with all the decades of improvements in automotive technology, they could figure out how to keep the bolts from corroding.
Ranchtruck
You have to smack that bitch up with a hammer before trying to loosen it. Seriously, pound on the head of the bolts like they were nails before you put a socket on them to turn them out. It breaks up the corrosion packed between the steel bolt and the aluminum housing.
If I can replace the water pump on a 98 explorer with 301k miles on it that spent it's whole life in the salty northeast without breaking a single bolt, you should be able to do it in sunny California.
broncnaz
While you may live there the junkyard vehicles most likely took trips to the coast. 150 miles is not so far. heck I thought stockton was a lot closer to the ocean like less than 50 miles straight line.
bronco t
San Diego CA
I got one from Michigan and it looks like it had the same problem, but I would bet that salty roads helped a lot.
Pat B
It's nothing to do with salt on the roads or salt from living on the coast. It's dis-similar metals corrosion between the cover and bolts....
When removing a timing cover, I'll make a good faith effort and smack it a couple times and then go right to the cut-off wheel....
Gotta' love it. Right?
Ranchtruck
Heat always works better than a BFH, but most junkyards get really antsy when customers start using torches out in the yard.
eastbaybronco
San Clemente CA
its actually amazing it hasnt been done yet, but the brass would create a dielectric union between the dissimilar metals and stopp corrosion , along with brass bolts
casadejohnson
Bronco Alchemist
In the last couple months I have pulled 3 of them and two were like you describe. I agree with the dissimilar metal argument. Usually the bolts back out at least some before they break I just got off the heads of the bolts. The same problem seems to come up with the front intake manifold bolts. They bust off in the head, that never has happened to me with a cast iron intake, just aluminum.
baddad457
Sometimes heat works better than a BFH...
X2 on this. The problem isn't unique to the Explorer cover, it's all the late small blocks. I think Ford quit using thread sealer on these bolts and the coolant seeps out the threads into the cover. I recently changed thge pump on my 96 E150's 351, I used heat and just enough torque on the bolt to gradually back it out without snapping the bolt. Apply heat (I used an electric heat gun, a small torch would do better) and apply a little torque to the bolt several times as the heat soaks into the aluminum. I had one bolt out of the whole cover that needed this to remove. All the bolts got a dose of aintiseize before going back into the holes.
baddad457
if you put a brass timing cover gasket in between the cover and the block you will never get corrosion! lol true but funny
Just use antiseize on the bolts.Problem solved. Teflon thread sealer on the four bolts that go into the coolant jacket works too.
pa69broncoguy
heat it, beat it , spray and repeat. even if its only a propane torch. I perfer pb blaster for the heavy corrosion.
Ill second the antiseize, ive pulled out horrible looking bolts and found someone put never seize on years ago
