bronko69er
EB Addict
That looks like it's be essentially the same thing (rremoving the bolt).
...Now you are looking at a rig or arms that already have the extensions. Remember, there were some extensions on the market before ours that did not thread on but simply welded with the weld being the only contact with the radius arm. The extensions may look similar but there is a huge difference. If you like, you can send me some pictures of the arms "close up of the extensions" and I can tell you if they are ours or not.
Thanks, Anthony.
Stone Crusher Steering...
Here's an idea. Why not replace the sqare tube with round tube, and put the heim on the front end of the bar, between the side plates. You can still pin it at the rear bolt hole, and I think you'll get rid of all the problems you're fighting with your design. Plus all you have to do is fab up the new arm and bolt it in. If you don't like it, just bolt the stock square tube back in and you're back to square one.
Its a great idea but I couldn't figure out a way to connect the tube with a heim to the stock radius arm mounts. I'd really prefer to leave those intact.
I dont think I could attach a heim on the round tube the way Chuck/BCB does with his square tube radius arms.
I'm all ears for ideas - it would be an easier way to go.
So in Summary...
You want to take a 600$ part and re engineer it into something it never was?
With the amount of time and money spent, you could run a link suspension.
So in Summary...
Are the stock radius arm frame mounts just bolted on? or are they also welded?
Here's another renegade idea that will let you keep the square tubing if you want to keep things looking the same from side to side:
Retain the heim joint at the frame mount, but at the front bolt at the axle end, add a urethane bushing. Then cut the tube just behind the side plates, add a (fine) threaded insert to one side, and a matching threaded rod to the other. Thread the two halves together almost until the square tubing touches. When you pin the rod it will work/act exactly like the stock radius arm. When you unpin it, the bushing will handle the up-down articulation, and the threaded section will handle the roation. Since you're only dealing with maybe 1/8 of a turn, the overall length of the arm won't change by more than a mm, which should be completely acceptable.
As long as you have a long enough threaded insert to prevent any wobble, and use some decent waterproof grease on the threads, the joint should last a lifetime. Since you have room to play with on the inside of the square tubing, I'd probably use as large of a threaded rod (or maybe an externally threaded piece of DOM?) as I could find. Say 1" or so. You're not going to bend that unless you're getting really crazy.
