...the fuse box is powered by a combination of alt power and solenoid power wires.
Yep. The battery side when the engine is off, the alternator side when the engine is running.
Then he's saying the bypass wire (maybe 8gauge) is big enough to go from alt to starter solenoid. I'm not entirely comfortable with that so I am on running a 4 or 6 gauge wire.
Nothing wrong with you going overkill for sure. Bigger is better up to the point it becomes just too awkward to work with.
But what he said was true too, to a certain extent. It's all about the combination of gauge AND length.
The factory wire is 10ga or thereabouts, but is probably over 10 feet long, which is what makes it too small for a high-output alternator. If it was only a foot and a half, you could probably run a 3G on it!
An 8ga wire is way more than enough for over 100 amps over just the 1 foot or so going directly from the alternator to the battery. But hey, why chance an overload or not being able to hook up that 250 amp alternator you find for a steal on Craigslist someday, right?
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So yeah, your 6ga or even 4ga solution will be great. I say go with 6 just because it's easier to work with and over just this short distance is more than enough.
I used 4ga on a recent build, but that was because we routed the charge wire back over the engine, along the firewall, inner fender, then to the battery. Much longer than most.
Does anyone see a problem using a maxi fuse instead? 60 amp? I figure that would be easier to replace on a trail then a piece of wire taped up in loom.
Absolutely. Like broncoman said, it's a great way to do it. And for the same reason you quote about being out on the trail. Much prefer an easy to replace fuse, rather than have to splice in a whole new section of wire in the rain or snow 100 miles from home.
Agree that 60 is more than enough to cover most EB's, and certainly the more stock-ish ones. If you're putting extra loads on the fuse panel from other accessories you might run, you could bump that up to 70 or 80, but your initial 60 is likely just right.
Have fun. Sounds like it'll be ready to fire any time!
