Most of the guys on our trips run the factory Mustang based EFI system. It works great, and everybody carries the spare parts that are crucial. ECU, distributor, TFI, coil, fuel pump. It's great when several people run the same stuff, more chances of getting the problem solved. Heat is the biggest killer of these electronic systems, that's why it's best to keep the sensitive stuff out of the engine compartment. This was what made the Explorer OBDII system superior to the older Mustang EFI.
The aftermarket EFI's are integrated systems and the ECU is part of the throttle body. If and when the ECU quits, I guess your choices would be to carry a carb with you, or buy a second EFI kit to carry at all times. For street vehicles, it's not a big deal. Just tow it home, but if you venture 1/2 day out from civilization, you better be prepared.
Mark
