Factory Seat Tilt Spring Removal?
aredoubleyou
SF Bay Area
I'm restoring an old set of factory seats. There's a spring that activates the footman loop hook which allows the seat to tilt forward. Is it possible to remove this spring? I'd like to treat it for rust and put it back or replace it entirely. The attached pics show which spring I'm talking about.
No idea at all. Never attempted it.
But I'll say that, as far as it looks to me, the only way to remove that spring is to press out the stud/pivot/axle for the latch and disassemble the entire group of parts.
As always, I'll be very interested to hear from those that might have done it.
Good luck.
Jetfixr320
Interesting idea to press it out with a C clamp + socket. I'll give it a try if there aren't other suggestions. Has anyone actually removed this pin/spring before?
I don't remember who or where I learned that from, Either my Dad or some old Crusty Aircraft mechanic (I resemble that person now). But, I remember pressing U-joints apart like that a long time ago, And just pressed some fasteners out of a hard to access area on a 767 just last week.
mock
Highland
I believe there’s a C clip/snap ring on the side that takes the chrome lever remove that and it should slide out if I remember correctly
I think I can see the snap ring in the picture
aredoubleyou
aredoubleyou
SF Bay Area
@mock - that worked! Thanks for pointing out that C clip. I totally missed it.
Pics attached for anyone who runs into this in the future. Pic 1: the C clip. Pic 2: the pin in normal position. Pic 3: the pin now loose and removable.
I guess now the question is: does anyone know where to source that C clip and new springs for the mechanism? I'll try to reuse what I have, but it might be good to just install new parts if they're available.
