Family Cage Options
LowCountryEB
Charleston, SC
I am trying to finish the design of my family cage. I am trying to decide if I should get the seat tie ins or not. I am 6'4" tall, and don't want the bar at the floor board to be an issue getting in and out. I am getting the tall man package. I don't rock crawl or go off-roading. It's simply a weekend driver to the beach or around town. What do you recommend?
Current Options
Pre-Weld/Tack/Mark for my welder
Tall Man
Frame tie-In
Seat belt tie-ins (Seat bungs)
Wheel well bars-Run along body / Not curved
Center Head Console for lights/switches
Windshield brackets tie-ins / Weld plate to cage / Bolt to windshield
Rear Bars to be horizontal and below body (can't see bar from a side view)
Grab Bars
***Seat tie-in's***
I have been talking with BroncoBob about the cage. Should I consider Bailie Built or any others? Is there anything else I am missing?
dukeflr
Yuma
I just finished my cage and took it to the powder coater yesterday. I moved the center overhead bars further inboard for more headroom. I also cut rear overhead bars but I took them out due to less headroom in the backseat for adults.
This is the time to make a final decision on seat belts too. I added the real mounts and shoulder bungs to use humvee belts.
I added 5 tabs total. 2 for dune whips, 2 for windshield brace turnbuckles, and 1 for a CB firestick.
Frame tie-ins for this cage won't be simple. The rear and fronts have floor supports under the cage pads. The driver B-hoop pad has the aux tank filler under it. Anything is doable but it won't be an easy add-on.
Yeller
Rogers County Oklahoma
For the design and lack of need for frame tie ins my vote is Bailie Bilt. I'm a very experienced frabricator and if I had a bronco needing a cage it would without a doubt be a Bailie. Gordon will also work with you to have the cage you want and above all be safe
wepuckett
If you decide to get seat tie ins I would love to see pics, as I also want seat tie ins but don't like the bar at the bottom just inside the door that you always have to crawl over. One of the purposes of my trip to super cel this year is too look at as many cages as possible to find exactly what I am looking for.
AxlesUp
Collierville TN
my general rule is if the belts are attached to the cage the seats should be too.
i'm going to use these guys once i get mine to that point: they are close enough for me to drive the bronco to for fitment.
http://classicbroncos.com/forums/showthread.php?t=271817
i'm running some horizontal bars along the inside of the bed rail so i can tie into them to strengthen the bedside much like the windshield frame. mostly because i don't run a top to keep it all square. i may do a cross bar back there to attach the rear shocks too.
73azbronco
In your example I recommend just a family cage, no cage tie in to body, belt retractor on frame though. I use Mastercraft Baja RS, very low profie, cushy and wide enough for me butt. I'm 6;1" and it works great.
I think unless you race, or serious level 5/10 rocks with verticals and high chance of rolling, a body bolted system is more than adequate.
My 2013 jeep has the seatbelts bolted to floor, retractor on the rollcage, so thats what I did with my 1973 family cage.
LowCountryEB
LowCountryEB
Charleston, SC
Duke-That's a nice looking cage! Did you build it yourself?
dukeflr
Yuma
It's a BroncoBob kit, without the tall man option. Doesn't have the kickers, instead the horizontal bed rail bars. Other than that, I did the fitting and welding. I bent the grab bars with a friend's bender and I own a notcher for all the fitment. I had my 3 point shoulder belts on hand to mock during the cage build.
I don't disagree with any of the advice in the thread, but the Bronco Bob cage serves many EB owners well. Pretty much any of the well known cages these days would protect your family. Choose what you like and do your part to avoid putting the bronco on its roof. Whatever you choose, it'll be way better than it is now or when new.
67RT
When the floor mounts hit the support, how does it look underneath. Do u just drill thru the supports and sandwich the plate around it?
sprdv1
REBEL
X2.... and he'll do anything extra you want done
