We are getting close to the end of our frame off 72 project and we just put the body on and I need to install the shroud.
I'm running a 302 and a new BC three pass radiator. Someone before me put on a 6 blade fan and the clearance between the fan and the radiator is approximatly 1". Is this the correct spacing ?
There is a 1 3/4" spacer between the pully and the fan. I will have alot of trouble mounting my BC shroud with this spacing. I can shorten the spacer to about an inch it that's what I need to do.
Your advice is appreciated, Thanks!!
