Fan switch wiring, help.
RedLeg0811
Maltby, WA
I have looked on the wiring diagram and it just doesn't show it very well. I have a 70 bronco. I know where the brown wire goes, but not the red or the orange. If I am face the switch from the back side, or sitting in the engine compartment looking in to the passanger compartment, which wire goes where?
Martin
SeaBiscuit68
Tacoma Wa
I don't have one in front of me so I can't answer according to the way you phrased it, bit I can in another way. Knowing where the brown one goes is the important part so just hook the other two up. Depending on which way you do it, it will be off - high - low, or off - low - high. I believe stock is off - high - low. I switched mine 'cause I thought that was weird.
