Fuel pump/Fan wiring from switch
Bundy
I am pretty sure that i tore out connections and relays for the electric fan and elec fuel pumps when i removed all the garbage wiring for the aux lighting from the PO.
My question is, to hook i back up i can just run a simple in wire mini-fuse right? what amp fuse do i want to run?
Thanks!
oleguy74
calif city ca
what ever the fan draws.and what ever the fuel pump draws.example!the heater motor in the bronco draws about 7 1/2 amps but is powered by a 20 amp fuse.that is for the surge at start up.your fan should say what size fuse.fuel pump should show fuse size
Bundy
Bundy
ok, i didn't install either of them but i will see if it says it on the fan or see what type it is... kind of looks like a Kragen special!
I have a Carter 4-7 psi elec pump, any idea on that one?
Viperwolf1
electron whisperer
For the fan circuit you'll want to run it through a relay and you'll need at least a 20 amp fuse. I'd use a relay for the fuel pump also and an inertia switch would be a good safety feature.
