Fender mounted regulator
MS73HD302
Anyone mounted a holley fuel pressure reg on the driver front fender to keep the fuel line above the block? Good idea or just overthinking it ? Mechanical fuel pump and factory power steering
-thanks
bmc69
What is your objective?...not sure I'm picking up on what it is you are doing there.
MS73HD302
MS73HD302
To keep the fuel lines from resting on the block or the hot power steering lines
SHX669
I mounted one on the firewall just to the left of the air vent {where the fuel line came in /up from the tank } but that Holley had rear facing fuel inlet capability . Worked great ; mounted a regulator and gage
knack
I mounted my regulator there. Right next to the windshield washer fluid tank.
Using it with an electric fuel pump.
bax
Old Member
Why a regulator with a mechanical pump?
bmc69
We used to do that back in the day so that we could cut the fuel pressure to carb down to only 2 psi or so for better trail manners.
MS73HD302
MS73HD302
This is what I ended up doing. My fuel was heating up and blowing the needle off the seat now it barely raises at all from limited testing. Running a 1850-2 at 5 psi
I appreciate the input from y’all
bax
Old Member
OK. little trick. 2 psi on a low speed trail should work all day. I get the concept.
bronconut73
Please re-think your fuel delivery .....i can tell you gave it some thought...and maybe it's just temporary but....
I do not want to be rude but that Sir is a fire hazard and I do not want you or your eb to get hurt.
Perhaps now that you have your regulator adjusted to where you want it you can remove the clear fuel filter and pressure gauge.
Install a safer (solid metal perhaps) fuel filter .... They have some that screw right into the carb or an AN style that would screw into your regulator.
There are lots of ways to do it.
Post up some pics fellas.
I went to an electric pump so my configuration won't help you as you appear to be running original mechanical style pump.
72Sport
Mounted the Holley regulator on the outside of the frame to the rear of the steering box where it is cool. I made a special fitting for a fuel pressure gauge so it would mount at the carburetor. I planned on removing the gauge after I set the pressure at the regulator but that was about 10 years ago. No fuel filter after the regulator. I think the q-jet has an internal filter in the carb. I also bought some insulating material to go over the fuel line from the regulator to the carb. I got the material from McMaster-Carr. I would not use a plastic fuel filter in the engine compartment.
