- Jul 31, 2001
- 9,345
Cutting holes in the cowl hood is more of a cosmetic feature than a cooling feature- unless you cut a lot of holes.
Then you have to weigh the fact that you are staring at all these holes you've cut into the back of the cowl evertime you drive it. Personal taste thing here...
Buy the inner fender vents from WH or make your own. They allow a tremendous amount of air to circulate within inches of the source of the most heat in your engine- both sides!
I cut my inner fenders out years ago and the amount of heat trapped under the hood has been reduced tremendously. I have no way of measuring except I don't have to replace the gas struts for the hood regularly anymore as the heat was killing them according to the engineers I talked with.
No holes in the hood to stare at all day either.
