Finally got around to swapping the 200 out
bigcountry
My 67 had a wornout 200 that a PO had put in it to replace the 170. It smoked, knocked, and was wornout with no power.
I have a 68 falcon that I bought from a guy with 84000 original miles and it runs great.
With the help of a buddy, I finally got around to swapping the engines out. I drove it this afternoon. I have a few clutch and shifter adjustments to make, but it feels like it has twice the power.
My radiator was shot also, so I made some brackets from angle iron to install the radiator out of the falcon which is a little larger and brand new without having to cut anything.
barronj
Looks like a clean install. I like the set up of your garage.
Pa PITT
Stephenville TEXAS
Big County no problem you'll love that little 200 .. I rebuilt a 200 too add to Running Buddy's 66.. IT RAN NICE FOR about 5 years then he swapped in a v8. i'M NOT SURE i DIDN'T like the 200 best.
bigcountry
bigcountry
Thanks for the compliments guys. It was a fun install.
bigcountry
bigcountry
Yes, we are planning to make Supercelebration again. I have some other stuff to do to it before then.
bigcountry
bigcountry
update
Just an update on the bronco. Added a weber carb to it. After I took it apart probably 8 - 10 times, i finally figured out the fuel leak problem. It really makes a difference in the power, but have not driven it enough yet to determine mileage or dependability yet. I am enjoying it so far. Now I have to work on installing weather seals, a speaker, and swapping in a lift from a parts bronco all before supercelebration.
bmbm
weber
Sounds good, did you go with a DSII? Have you been to fordsix.com?
bigcountry
bigcountry
I assume DSII is a dura spark. No, I installed a pertronix ignitor. I have been to the site. Lots of great information, I called Clifford yesterday to discuss problems with him. Nice guy, helped be get her going.
bmc69
Nice!. I keep debating getting another 6 'on the road'. The two 170 EBs I have are mainly 'field beaters' but I have 2 300s, a 240 and a 200 all sitting here doing nothing.%)
I liked my old DD EB with the 250..a lot. Reliable as a hammer.
bigcountry
bigcountry
the sixes are fun. This is going to be my knock around, hunting, and fishing rig for right now. I hope to start my other build pretty soon. It will be 8 cylinders though.
bigcountry
bigcountry
Thanks, but I have 3 and a 351w. I am building a 347 for this project.
mudstud
Bronco Bonehead
Excel
That is my problem. I have more than I need. Two 302s and I will be installing a 351 soon.
