jake2077
- Dec 6, 2018
- 106
Long story short, rebuilt the 302 and trans while body and frame were being worked on. Today we reinstalled the engine with trans and all went fairly well .. until I tried to close the hood. Body was on 1" lift and still is with new bushings front to back. Motor mounts were replaced (could this be it?) and after comparing before and after they look the same. I'm at a loss as to why the block is sitting up higher than before, so high that the distributor cap w/wires attached is bumping the hood not to mention the air cleaner. Hood was replaced with identical make as well. Some pictures before and after.
Also, this is the mount I purchased from RockAuto, https://www.rockauto.com/en/moreinfo.php?pk=5404308&cc=1105456&pt=5552&jsn=7
Before
After
Before
After
