74bronk
- Sep 1, 2004
- 358
For several months I had this annoying tick comming from the motor....at first I speculated that it was the valves on cylinder 1 need adjusted. But nope that wasnt it then it seemed to be a loose timing chain but luckily while trying to narrow down the noise I ran my hand along the bottom of the header on passenger side and felt a huge rush of air shooting out!! Turns out the Exhaust gasket was blown in two spots on cylinder 1. So I purchase aluminum gaskets and install. Then I checked the collector side on both headers and the bolts were loose as hell,exauhst was just pouring out of them! Exauhst guy on install didnt tighten bolts. (note to self periodically check collector bolts!) then I ordered a. New sending unit for gas tank a month ago so I decided today is they day I fixed this damn gauge issue. I remove old one then decided to check resistance with meter and it checked out fine!! WTF! Compared to new one it read the same!
Then I noticed the float was filled with gasoline! Ah so that's why it didn't work!! The original one I installed worked fine for about 2 years then always stayed on empty. Come to find out there was a pin hole in the "plastic" float! It filled up and just sank and stayed there! Well the new one has a brass or copper float hopefully it won't fill up like the previous one did. Something to think about for anyone replacing the sending unit!
Also bought e3 spark plugs I have to say so far I've noticed a big difference in the smell of the exhaust.. Less fule in the air! Little more power to! I'll Have to measure my mileage and post!
sorry just wanted to share my Bronco experience with somebody!
